im still confused about filters. the one i took of ages ago had a bracket fixed to it and i bought a new one and it didnts but i dunno if its because it used to be a sportif if the fittins are different. cable ties to the rescue ha
the blueprint one i bought you had to swap the bracket of the old one, just bought toyota one and comes with bracket although still dont think its the same as whats come off even tho part number same the inlet hole is still bigger so see if it seals later
will the standard fuel filters fit the glanza v
