As above at the end of the month I'll be looking in buying a td04 mani a real good one what prices do they start from cheers also I got a td04 decat already what elese is required to bolt it all on ? Like lines nd all that and what actuator do u use cheers
So what's that about 400 odd quid ? Do the come with gaskets good ones ? Also do u no what elese is needed to make a td04 set up complete cheers
I was doing my research aswell for this setup up bud. As far as im led to believe you will need
TDO4 Turbo
Manifold and Downpipe
Oil feed and return line
Water lines
Actuator and bracket (for internal wastegate setup)
Samco silicone 90 bend for air intake
TD04 Routed hot piping for your FMIC
Now the TD04 requires to be rotated in the centre so that the oil feed is at the top and the oil return is at the bottom. The compressor housing also gets rotated so that it faces downwards, this then means the actuator bracket is no use and a custom one is to be made.
Hope this helps bud
