silverglanza Posted August 12, 2010 Share Posted August 12, 2010 As above at the end of the month I'll be looking in buying a td04 mani a real good one what prices do they start from cheers also I got a td04 decat already what elese is required to bolt it all on ? Like lines nd all that and what actuator do u use cheers Quote Link to post Share on other sites
CLARKYTRD Posted August 12, 2010 Share Posted August 12, 2010 WEPRThey are doing unbeatable prices over on tgtt.Check them outCant rate them high enough Quote Link to post Share on other sites
silverglanza Posted August 12, 2010 Author Share Posted August 12, 2010 How much are they I ain't a member well I was but 4 got my details Quote Link to post Share on other sites
CLARKYTRD Posted August 12, 2010 Share Posted August 12, 2010 mild steel manifold and decat combo for $560 DollarsWhich is very cheap compared to the usual price! Quote Link to post Share on other sites
silverglanza Posted August 12, 2010 Author Share Posted August 12, 2010 So what's that about 400 odd quid ? Do the come with gaskets good ones ? Also do u no what elese is needed to make a td04 set up complete cheers Quote Link to post Share on other sites
Johnboy GT Posted August 12, 2010 Share Posted August 12, 2010 So what's that about 400 odd quid ? Do the come with gaskets good ones ? Also do u no what elese is needed to make a td04 set up complete cheersI was doing my research aswell for this setup up bud. As far as im led to believe you will needTDO4 TurboManifold and DownpipeOil feed and return lineWater linesActuator and bracket (for internal wastegate setup)Samco silicone 90 bend for air intakeTD04 Routed hot piping for your FMICNow the TD04 requires to be rotated in the centre so that the oil feed is at the top and the oil return is at the bottom. The compressor housing also gets rotated so that it faces downwards, this then means the actuator bracket is no use and a custom one is to be made. Hope this helps bud Quote Link to post Share on other sites
rinseep82 Posted August 12, 2010 Share Posted August 12, 2010 have a look at some of ricky lee race tech manifolds his fabrication is awesome his minis are chunky as fooook lol Quote Link to post Share on other sites
