plenty of holes for bolts in the front end you can put them. i looked for holes to make some FMIC brackets fit into and was chuffed with how many spare holes there were :p
If it's for 'show' then strap it somewhere secure.
If it's for serious use, then I would be sure to mount it somewhere firm and strong.
Thanks for the replies, I found the bolt in the belly pan looks to be perfect! :p I'll mount mine of the same bolt when it comes through the post :D
Only for looks at the moment :D
