I am thinking about buying Greddy E-management off of pistonheads but unsure if it has all wiring/harnesses i would need 2 install it just looking for some guidance.
Have a look - http://www.pistonheads.com/sales/1949093.htm.
has the ignition harness
has the injector harness
it has another harness but dont know what that is for
it has the map sensor harness but no map sensor.
Looks to be ok to me.
The emb will be fine will just need a remap obviously.
The universal harness i think hes pictures, one end plugs into the emb and at the other end should be a few odd wires that will need to be spliced into the oem loom of the car, would get someone who knows what they are doing to do that,
You will need an ignition harness and an injector harness too i beeive.
i think you will need a 3bar sensor if your running over 1bar of boost, if not stock is fine i think
Yeah i think you are right sanchez the stock map sensor is good for 1.2bar
