Apexi Ecu Need Advice From Someone Who Has One Or Had One And Knows About Them
Right i have this so far
I need help guys like i have this map sensor
But i thought you needed an apexi one to work with the Apexi ecu also do i use the wiring on my original cars map sensor or do i need another lead?? this has
sensor assy, turbo pressure
Toyota
89420-20310
100798-3100
5v
denso japan
sticker on it is this just the standard one on the car i thought an apexi one would have apexi on it???
duno why you didnt take mine mate?and thats the factory one you got there.
the map sensor that was in my car and was sold to you was the 2.0bar map sensor out of a celica, the apexi power fc map sensor is a 3.0 bar map sensor.
The power FC can run any map sensor as long as you change the offset and scale settings to suit.
But having the apexi one is alot easier and less time consuming for the tuner
how do you mean to fix it like or to map it?
Spoke to Gary on the phone top bloke cleared up alot of things top bloke for that can't wait for the rollers
