jayep91 Posted August 27, 2010 Posted August 27, 2010 tryed twice now to seal the oil pump its brand new any ideas why it could be leaking? Quote
steed Posted August 27, 2010 Posted August 27, 2010 oil pump might be warped? unlikely i know but possible. has james had a look? what's his verdict (i'm guessing the car is still at JD modified?) Quote
Russleh Posted August 27, 2010 Posted August 27, 2010 defo the right oil pump for the block? some of the pumps have the seal / big oring in them but sometimes they are in the block. if you ended up with a space for the seal in both that would cause problems i would imagine. Quote
jayep91 Posted August 28, 2010 Author Posted August 28, 2010 yeh still a jd i dont think its warped but im gonna check today so it there to types of oil pump then?? Quote
Russleh Posted August 28, 2010 Posted August 28, 2010 yeh its just one that has a grove in it for the seal to sit in and one that doesnt because the seal is in the block. 2 oil pumps because there are 2 diff blocks. Quote
jayep91 Posted August 28, 2010 Author Posted August 28, 2010 o right speed vision sent me the wrong 1 then cheers 4 the info dude Quote
jayep91 Posted August 29, 2010 Author Posted August 29, 2010 speedvision? Theres your answeryep they are useless they sent me out to sets of cams aswell that didnt shim up Quote
