Low Boost, Low Power
well lads i got a 96 glanza turbo with the following mods:
a/c removed
front mounted air filter
boost solenoid bypassed
s/s manifold
s/s downpipe
full exhaust system
problem im having is that my car is low on power and its not boostin right
max boost i can get is 8psi but usually its at 6psi, 2 of the 3 turbo boost lights on the dash only come on in 1st n 2nd
in 3rd, 4th, 5th the 3 lights come on at high revs but sometimes go back off
any idea what this could be?
also the vacuum pipe normally connected to the efi pipe isnt connected to anythin now as shown below...
Cheers
Dean
  DavidAshton said:
Standard actuator?
If so thats your problem, junk it and upgrade.
Also iirc the pipe that isnt sonnected at one end looks connected to the second port of the standard actuator. If you block it you will be in low boost forever. So dont.
thanks man i think i may just get a hks actuator so, should solve my problem!
