garya Posted September 12, 2010 Posted September 12, 2010 Awryt guys just bought my first starlet gt tonight,only slight problem tho when i put the foot down and the revs go pritty high it seems to judder as if its getting starved of fuel or somthing i dont have a clue about these cars could someone point me in the right direction.p.s sorry if i have posted this in the wrong place thanks. Quote
glanzav.tee Posted January 31, 2011 Posted January 31, 2011 check compression, earth cables, check plugs, check dizzy cap for carbon build up, change ht leads one by one, make sure its fueling if not you may have a weak fuel pump, and check to see if you have got a hks fcd and if so and your running standard without fueling mods remove it or turn it off on 0 Quote
