Specifications
Dimensions
Overall length mm (in.) - 4160 (163.8)
Overall width mm (in.) - 1660 (65.4)
Overall height mm (in.) - 1290 (50.8) *1 - 1325 (52.2) *2
Wheelbase mm (in.) - 2380 (93.7)
Front tread mm (in.) - 1405 (55.3)
Rear tread mm (in.) - 1395 (54.9)
*1: Coupe
*2: Convertible
Weights
Gross vehicle mass (GVM), kg (lb.): 1385 (3053)
Maximum permissible axle capacity (MPAC), kg (lb.):
Front 750 (1708)
Rear 750 (1708)
Drawbar load, kg (lb.): 50 (110)
Towing capacity*, kg (lb.):
With brake 1000 (2204)
Without brake 450 (992)
*: On gradients up to 12%
Engine
Model: 5E-FE
Type: 4 cylinder in line, 4 cycle, gasoline
Bore and stroke, mm (in.): 74.0 x 87.0 (2.91 x 3.43)
Displacement, cm3 (cu. in.): 1497 (91.3)
*cm3 = Centimetres Cubed
Fuel
Fuel type: Unleaded gasoline, Research Octane Number 95 or higher
Fuel tank capacity, L (gal., lmp. gal.): 45 (11.9, 9.9)
Service Specifications
Engine
Valve clearance (engine cold), mm (in.):
Intake 0.15-0.25 (0.006-0.010)
Exhaust 0.31-0.41 (0.012-0.016)
Spark plug type:
NIPPONDENSO PK16R11
NGK BKR5EP11
Spark plug gap, mm (in.):
1.1 (0.043)
Drive belt deflection with 98 N (10 kgf, 22 lbf) thumb pressure (used belt), mm (in.):
1 5.0-6.5 (0.20-0.26)
2 12.0-14.0 (0.47-0.55)
3 9.0- 11.0 (0.35-0.43)
Engine Lubrication
Oil capacity (drain and refill), L (qt., lmp. qt.):
With filter 2.8 (3.0, 2.5)
Without filter 2.6 (2.7, 2.3)
Oil grade:
API SG or SH multigrade engine oil or ILSAC multigrade engine oil.
Cooling System
Total capacity, : (qt., lmp. qt.):
Coupe 4.9 (5.2, 4.3)
Convertible 5.2 (5.5, 4.6)
Coolant type:
With ethylene-glycol antifreeze ("Toyota Long Life Coolant" or equivalent)
(Do not use alcohol type antifreeze.)
Battery
Open voltage* at 20*C (68*F):
12.7 V Fully charged
12.3 V Half charged
11.9 V Discharged
*: Voltage that is checked 20 minutes after the key is removed with all the lights turned off.
Charging rates : 5 A max.
Clutch
Pedal freeplay, mm (in.):
5-15 (0.2-0.6)
Fluid type:
SAE J1703 or FMVSS No.116 DOT 3
Manual Transaxle
Oil capacity, L (qt., lmp. qt.):
1.9 (2.0, 1.6)
Oil type:
Multipurpose gear oil API GL-4 or GL-5
Recommended oil viscosity:
SAE 75W-90
Brakes
Minimum al clearance when depressed with the pressure of 490 N (50 kgf, lbf) with the engine running, mm (in.):
55 (2.17)
1-6 (0.04-0.24
Parking brake adjustment when pulled with the force of 196 N (20kgf, 44lbf):
5-8 Clicks
Fluid type:
Steering
Wheel freeplay:
Less than 30 mm (1.2 in.)
Power steering fluid type:
Automatic transmission fluid DEXRONII or III
Tires
Tire size:
185/60R14 82H
Tire size Galliano:
195/50R15
Tire pressure, kPa (kgf/cm2 or bar, psi):
160km/h (100mph) or over:
Standard inflation for all loads including full rated loads
230 (2.3, 33)
Optional inflation for reduced loads (1 to 2 passengers)
220 (2.2, 32)
Under 160km/h (100mph)
200 (2.0, 29)
Wheel nut torque, Nm (kgfm, ftlmp):
103 (10.5, 76)
