Galliano Posted September 16, 2010 Posted September 16, 2010 Toyota Vehicle Security System TVS IIIB Owners ManualOperating InstructionsTop Button ><Bottom Button <>UNLOCK (Disarm) - Press = Once (<>) - Hazard Light Indication = Flash Twice - LED Indication = Stop Flashing*Note: If door is not opened within 30 seconds, doors will relock automatically.LOCK (Arm) *With interior protection* - Press = Once (><) - Hazard Light Indication = Flash Once - LED Indication = Start FlashingLOCK (Arm) *Without interior protection* - Press = Twice (><) - Hazard Light Indication = First Press - one short flash, Second Press - one long flash - LED Indication = Start Flashing*WARNING: When the system is armed do not unlock and open the vehicle (doors or boot) by the key method as this will sound the siren.System FeatureTVSS IIIB is a system which offers an addictional Theft Deterrent to complement the Engine Immobilisor System (EIS) described in the owners manual.The TVSS IIIB is designed to detectA. Movement within the vehicle's interior. (if selected on the handset)B. Opening of doors, boot or bonnet.C. Disconnection of the battery.D. The sound of glass being attacked. (for the following vehicles only: Carina E Estate, Previa, Rav4 5-door, Landcruiser 80 and Hiace).When the system is armed and one of the above conditions is detected, the hazard lights will flash and the siren will sound for 30 seconds.To Stop The Siren Sounding-If the siren sounds pressing the Remote Control Lock Button will cancel the siren and leave the vehicle doors locked and the system armed.-Pressing the Remote Control Unlock Button will cancel the siren and disarm the system. If a door or bonnet is not opened within 30 seconds, the doors will automatically lock and the system will arm.System OperationSECURITY LEDThe LED operates as shown above.WARNING: It should not be relied upon to indicate that the vehicle is armed/locked as it will also operate under the following conditions:Turn Ign. off -> Exit Vehicle -> Close Door -> LED FlashesIf the doors are subsequently opened, then closed (without operating the remote control), it will continue to flash.If the unlock button is pressed, it will stop the LED flashing.*^*^*^*1. The vehicle is supplied with 2 remote controls. Up to 4 remote controls can be programmed to operate the system.*WARNING : If all of the remote controls are lost, the central control unit will have to be replaced.2. For the system to function correctly all doors, the boot and bonnet must be fully closed.3. By pressing the Lock Button twice the vehicle is locked and the system is armed without interior protection. This could be necessary if people or pets are to be left in a locked vehicle for a shot period of time.If the Lock Button is pressed a third time the system will remain armed, but with interior protection reinstated. The interior sensor can now be turned on and off with successive operation of the Lock Button.4. If the vehicle is unlocked using the remote control, but the boot or doors are not opened within 30 seconds; the security system will automatically rearm and lock the vehicle.5. The interior light will be switched on for approximately 5 seconds when the system is disarmed.6. The security system has a memory; in the event that the system was activated during your absence, the hazard lights will flash 3 times when the system is disarmed.Note: Unlocking the vehicle by key (doors or boot) will not disarm the alarm system.In Case The Remote Control Does Not Work1. Check whether the LED on the remote control lights up. If not, the battery may need replacing.2. In case the system has lost its synchronisation, press both buttons of the remote simultaneously for two seconds. This should return the system to normal operation.3. If another remote control is available for the vehicle, check for its correct opperation. If not, contact your local dealer.Replacing The Remote Control BatteryIf the remote control range becomes shorter or its LED has become weak or dim or refuses to work at all, you must replace the battery of the remote control. Batteries are available from your local Toyota DealershipPart Number : 08192-00960.*Nota :The LED on the remote control will indicate the status of the remote control's battery. The LED will dim BEFORE the remote control becomes inoperable.Changing the remote control's battery will not erase the remote control's code from the main control unit.We recommend replacing the battery at every maintenance period to ensure that the remote control works properly. Under normal conditions, batteries have a lofe of about one year. The battery fitted at the factory my have a shorter life. There is no need to remove the remote control printed circuit board while replacing the battery.Replacing The Battery1. Remove the screw on the back of the remote control.2. Remove the rear cover.3. Take out the old battery.4. Insert the new battery (CR2025/LITHIUM) with positive (+) side facing to the rear cover.5. Refit the rear cover and check that the remote control works.*Nota : Avoid touching the battery with bare fingers, as body moisture may effect contacts and prevent the unit for working properly.Dispose of the old battery in a safe way. Quote
