hulahoops Posted September 18, 2010 Posted September 18, 2010 needing help asap to fit hks turbo timer. dont have a clue guys im useless with wires please help Quote
ToyotaTech15 Posted September 18, 2010 Posted September 18, 2010 My first piece of advice is if you are unsure about doing it urself get someone who knows what to do to fit it for you.Are you using an ignition loom wiring harness? Or is it just hard wired in?Gary Quote
hulahoops Posted September 18, 2010 Author Posted September 18, 2010 em theres two white block on the end of all the wires??? i asuming that plugs into the ecu??? is that what your on about Quote
hulahoops Posted September 18, 2010 Author Posted September 18, 2010 ill go ask my al man hes a mechinac but he works for shitty vauxhall so he wont have a clue Quote
ToyotaTech15 Posted September 18, 2010 Posted September 18, 2010 It's hard to say without having a look at pictures. By the sounds of it and going by the last one I fitted, the White blocks your meaning are connectors and they will plug into your ignition switch wiring.There will also be a spare wire for your handbrake switch and possibly an earth depending on what kind it isGary Quote
hulahoops Posted September 18, 2010 Author Posted September 18, 2010 It's hard to say without having a look at pictures. By the sounds of it and going by the last one I fitted, the White blocks your meaning are connectors and they will plug into your ignition switch wiring.There will also be a spare wire for your handbrake switch and possibly an earth depending on what kind it isGaryyeah garry thats right its a type 1 and theres a brown one for the earth and a gray one for the handbrake cheers mate Quote
