i picked up this EMB from someone last night, im unsure what harnesses i need as it was wired into an ep82 field harness but the seller took that, so im unsure what i now have, i know it has the 3 bar map sensor and possibley the ignition harnesses that plugs into the main unit but do i have the injector or main harness? heres some pictures (remember the field harness has been cut off) im pretty sure i have ignition but can i get the injector harness and map it, or do i need a main harness? if so what does it look like....
Thanks
