ktl Posted October 9, 2010 Posted October 9, 2010 My car was mapped 2 weeks ago for 0.8bar, 1.2bar, and 1.3bar.Today i noticed in 3rd gear @ 1.3 bar comes in rich in the 11s, and @5.5-5k goes into the 12s 12.5 I've seen, then after 5.5-6k richens back into the 11s.4th gear is bang on between 11-12afr i tested the other pressure settings and all in between 11-12afr. So im thinking why in 3rd gear and @1.3bar it runs leans for a short time...any ideas would be greatAm i right i should be going for grade 8 sparkies ? running just under 270hp and using grade 7 atm. Quote
ktl Posted October 10, 2010 Author Posted October 10, 2010 anyone ?i noticed its doing it in 4th now. 5th is ok. Quote
edd 5512 Posted November 2, 2010 Posted November 2, 2010 wouldnt worry about it mate, it's not exactly lean. if it was in the 13's then i would be looking at richening it up. the recent spell of cold weather is probably to blame - colder air is denser - so more oxygen per metre cubed - leaning your air to fuel ratio Quote
gts-t Posted November 2, 2010 Posted November 2, 2010 colder weather shouldn't affect it if it's been mapped properly. the cold weather will cause you to hit a higher ecu load though and the cells in that particular rpm range won't be putting in enough fuel. Quote
ktl Posted November 3, 2010 Author Posted November 3, 2010 got it sorted. went back to have a road map which didnt cost nothing to add more fuel. it wasnt detting was that was a good thing. now hes added more fuel we added the boost up so peaking 1.5bar now but to hold for 1.4bar. Quote
edd 5512 Posted November 3, 2010 Posted November 3, 2010 colder weather shouldn't affect it if it's been mapped properly. the cold weather will cause you to hit a higher ecu load though and the cells in that particular rpm range won't be putting in enough fuel.please do explain?the boost pressure could be the same only have more oxygen in it per metre cubed, so more air, so at the same boost value it runs leaner. the value in the ecu cell in the likes of an emu could not accomodate this. Quote
