Wesgtt Posted October 22, 2010 Share Posted October 22, 2010 Hi I have just heard a knocking from my bottom end on start up I got the man from the local garage to take a quick look without taking it apart and he said defo big end shells have gone.Just wondering how easy is it to change the shells? How do I measure the crank to see if it needs a regrind? What else do I need to look out for or replace while doing it? I just need it to last about 6 months while I save up for forged internals.Also hiw much would the bits cost? Any help really apreciated.Cheers Quote Link to post Share on other sites
sx_turbo Posted October 22, 2010 Share Posted October 22, 2010 depends on how early you ahve caught the problem.you might be able to get some std size shells and whack them in there, but imo seeing as the engine probably got to come out any way, might aswell do a strip down and freshen up Quote Link to post Share on other sites
Wesgtt Posted October 22, 2010 Author Share Posted October 22, 2010 If I have cought it early will swapping the bearings over last me for a while? Need to do it as cheap as poss at the minute because of work, then look into rebuilding as early as poss next year!! Or if I do take it out to freshen it up what do you recommend to change? Thanks Quote Link to post Share on other sites
sowerby Posted October 22, 2010 Share Posted October 22, 2010 Forge the baby Quote Link to post Share on other sites
Wesgtt Posted October 22, 2010 Author Share Posted October 22, 2010 Haha i want to forge the engine but need to wait till next year to get the funds together! Been offered a cheap block so might build that and try and fix the one in my car without taking the engine out if poss? Also how I check for wear and what to look out for e.c.t? Cheers Quote Link to post Share on other sites
Shib786 Posted October 22, 2010 Share Posted October 22, 2010 If it is just doing it on start up, i think you should take off the sump and whack some new bearings in....then rebuild at a later date, no need to take out engine to do just bearings.. Quote Link to post Share on other sites
Wesgtt Posted October 22, 2010 Author Share Posted October 22, 2010 Yeh when you turn the key it knocks for about a second then goes!! garage said bearing straight away but tbh you could tell by the noise! it dosnt knock on tickover but if you rev it sometimes it comesback and sometimes not,hope i have cought it early.Can anyone tell me if the crank will be visably worn or if it needs mesuring? is it a simple take out put new ones in job? i have done some engine work before but not bearings, anything to look out for? e.c.t? torque measurements? a write up on doing it? Help really really apreciated its my daily driver so need it doing asap! cheers Quote Link to post Share on other sites
Shib786 Posted October 23, 2010 Share Posted October 23, 2010 id do a lot of reading up, its not something you want to mess up...if you have any friends that are mechanically minded that can help then get them, its not too hard tbh, just depends how mechanically minded you are.. Quote Link to post Share on other sites
kane88 Posted October 23, 2010 Share Posted October 23, 2010 i did may bearing on the floor out side my house if it is just the conrod bearing they anit that bad to do u got to tack the sump down then the oil strainer off and they are looking at u did my but the bearing were f**k and it lasted 5 to 6 months just dont drive round like a mad man Quote Link to post Share on other sites
Wesgtt Posted October 23, 2010 Author Share Posted October 23, 2010 Cheers for help hope i is just the bearings!! I am quite mechanically minded and my make is a lot better than me. Any one know were there is a good read up? Thanks Quote Link to post Share on other sites
Wesgtt Posted October 29, 2010 Author Share Posted October 29, 2010 Anyone know were there is a guide to doing big end bearings? really need a bit more info on it. any help appreciated. cheers Quote Link to post Share on other sites
