Are the angles of the elbow coming off the backboxes the same as i have been offered a back box that was on a glanza to go onto the sr... Will it bolt straight on or will i have to adjust it some bit!
The elbow im on about now is just over the axle where it is clamped together to the rest of the exhaust!
By da way,its a Glanza V backbox
i think the angles might be sligthly different but the sixe of the pipe could also be different going from a N/A to a turbo exhaust. you would need to compair them both side by side
everything should be the same, bar the fact that the pipework is slightly larger, so you'll have to adapt it to fit.
All rite lad,nice 1 ;)
So basically its fine if the bore is slightly bigger, you will need it welded onto the end of your exhaust, also you will more than likely need custom brackets welded onto the backbox so it can be hung if it has none.
Mine is welded on, slightly bigger bore and had the old tte backbox brackets welded on, rattles a bit sometimes on idle and low speeds but is sweet as a nut.
Joz
