Evening people
Basically a garage took my decat off for its MOT and ended up snapping the bots in the decat and now after it im looking to put the decat back on...
.How much will i be looking at to get them drilled out the decat and re-threaded?
.Should i take any action against the garage? (ie tell them to sort it out seeing they personally did the damage themselves)
.Is there anywhere that i could send it to that will do it for a cheap price?
Thanks for your time guys
Matt.
It wont be expensive to fix but i would be telling the garage to fix it as they done it.It will only cost them a couple of quid on bolts and 10 min to retap it.
Matt buddy get on there arse and get them to sort it out... they messed it up they need to fix it! as above though they shouldn't put up a big fuss and its not a big problem.
fuck re tapping it, drill the sucker out then nut and bolt.
my old decat had threaded flange and it dint bloody line up straight so I got the cordless out drilled the thread out and stuck a nut the other side
LUKESR WHERE THE BLOODY HELL YOU GET YOUR AVATARS??? you tease you lol
Secret :D
