hill_bill10 Posted October 27, 2010 Posted October 27, 2010 hey guys, my handbrake seems to be sticking on a lot atm, not sure why.ill take my handbrake off but the wheels will still be locked up and ill need to set off in order to jolt it looseany ideas why?o by the way im still on standard n/a drums Quote
gtmuzz Posted October 27, 2010 Posted October 27, 2010 your cables could be a bit corroded/rusty inside as as they are under the car exposed to the elements its highly possible How many clicks will hold your car on a small hill ?? have you adjusted it lately?? Quote
hill_bill10 Posted October 28, 2010 Author Posted October 28, 2010 erm not sure tbh, bout 6 ishand no not recently Quote
james@cjperformance Posted October 28, 2010 Posted October 28, 2010 brake cylinders are more than likely shagged.the seals go on them and they will not hold or release the hanbrake properly.pop the drum of and peel back the rubber on the cylinder if it leaks fluid its had it. Quote
Craig_T Posted October 28, 2010 Posted October 28, 2010 Just put WD40 all over your brake discs, that will stop any sticking...P.S don't do that. Quote
LukeSR Posted October 28, 2010 Posted October 28, 2010 Just put WD40 all over your brake discs, that will stop any sticking...P.S don't do that. :D Quote
hill_bill10 Posted October 28, 2010 Author Posted October 28, 2010 haha while im at it craig ill put some copper slip on it too shall i? Quote
