BIT OF A tricky one this guys!! i was changing my speedo bulbs AND.........................
hi guys, well basically just to cut a loing story short, i was changing my speedo dash bulbs on my glanza as one of them had gone and i was trying to get the one out where the engine heat gauge is and the bulb bloody pushed right through behind the cluster and dials, so now where there is meant to be a bulb behind the heat gauge i just have a hole, any idea's on getting these back out?
i am guessing its like a circuit board on the back and these just twist on to it or something? arrrrrrrrgh lol and is there any guides for removing the speedo cluster etc?
ta muchly!!
Mat :D
topic moved, u had posted in the photo section :D
anyways, yes the bulbs twist into the circuit board, so if the bulb has gone right through to behind the facias, u will need to remove the clear plastic cover on the cluster, then pop off the black surround that dresses over the facias, and u should see the aforementioned bulb rolling around like a kid in a playground!
hope this helps, if not, just shout dude!
Phil.
