Blue Icarian Wings Posted December 17, 2006 Share Posted December 17, 2006 Anybody changed/removed/swapped their door handles?I've learnt how to removes the door card, and can see one of the bolts needed to remove the handle.However the other is under a piece of metal that is welded to the window glass runner (it's a brace/stay I think)The dark grey bit (I've removed the screw in the bottom right cover that holds it steady)Has anybody any experience in dismatling this part of the door's guts?Thanks in advance ;) Quote Link to post Share on other sites
miracle411 Posted December 17, 2006 Share Posted December 17, 2006 Yeh i changed mine, bit of a ball ache really. Two bolts holding the handles in place either side of it. 10mm i think they are, pretty tricky to get to but it will come off, also there's a small green clip holding the rod in place don't lose that down the door as i did, quite fiddly to do but possible without going crazy. Quote Link to post Share on other sites
Blue Icarian Wings Posted December 17, 2006 Author Share Posted December 17, 2006 Thanks man:)After undoing both bolts, do I just pull the handle off, or do I need to try the impossible and unhook the latch rod I can't see a way to get too? Quote Link to post Share on other sites
miracle411 Posted December 20, 2006 Share Posted December 20, 2006 If i remember i unhooked the rod from the outside after pulling hte handle off, there should be a little bit of play in it. Quote Link to post Share on other sites
Blue Icarian Wings Posted December 20, 2006 Author Share Posted December 20, 2006 Thanks, all I need now is some courage, and not the Dutch kind! Quote Link to post Share on other sites
ecksjay Posted December 21, 2006 Share Posted December 21, 2006 ....hammertime? Quote Link to post Share on other sites
Mart Posted December 21, 2006 Share Posted December 21, 2006 Sorry to go off topic but anybody know how to replace the spring that keeps the handle in tension. I think the spring on my drivers door is after slipping out but I can't get at it. Its making the handle loose and flappy with no tension.Any ideas how to fix it? Quote Link to post Share on other sites
Blue Icarian Wings Posted December 21, 2006 Author Share Posted December 21, 2006 Just had a look at the set to go on, the spring is around the hinge (open the handle fully and look up inside it to see the spring), to do anything with the spring the handle will have to come out.I can share the dark secrets of getting the door card off so you can play with the handle is you want Quote Link to post Share on other sites
addz Posted August 17, 2008 Share Posted August 17, 2008 Sorry to go off topic but anybody know how to replace the spring that keeps the handle in tension. I think the spring on my drivers door is after slipping out but I can't get at it. Its making the handle loose and flappy with no tension.Any ideas how to fix it?I have just encountered this problem.Anyway in fixing the tension spring from outside without removing the door card??Thanks in advance Quote Link to post Share on other sites
Tintin_SR Posted August 18, 2008 Share Posted August 18, 2008 the bit of metal in the way is part of the window runner just unbolt it, its a bolt on the bottom corner of the door Quote Link to post Share on other sites
addz Posted August 18, 2008 Share Posted August 18, 2008 The plastic clip on the handle that holds the spring in place usually breaks. If that's what has happened it's a new handle that is needed.To remove it's two 10mm bolts and a plastic clip holding the handle to the locking rod. A bit fiddly but no biggee.The plastic clip has not broken off.The compression on the spring has been released when i opened the door over the weekend.I need to attach the spring back onto door handle housing, is it a matter of sticking in a screw drvier to ping it back in? Quote Link to post Share on other sites
addz Posted August 18, 2008 Share Posted August 18, 2008 I'll get a pic of what I mean mate. 9 times out of 10 the retaining part of the handle that tensions the spring breaks.Cheers mate.I will also try to get a picture to show the problem. Quote Link to post Share on other sites
kevink Posted August 19, 2008 Share Posted August 19, 2008 I only can say one thing its an hell of a job!!!the springretainer popped on mine, 2 weeks later i pulled the entire handle of due to that fact. i installed a new one but its a very very annoying thing to do, if you dont take out the window... Quote Link to post Share on other sites
addz Posted August 19, 2008 Share Posted August 19, 2008 I only can say one thing its an hell of a job!!!the springretainer popped on mine, 2 weeks later i pulled the entire handle of due to that fact. i installed a new one but its a very very annoying thing to do, if you dont take out the window...Ouch!So once the springretainer popped on you did you carry on using the car resulting in the entire handle comming off?I was thinking about leaving it for now if its an ANNOYING job.Picture attached Quote Link to post Share on other sites
