Idrees Posted November 4, 2010 Posted November 4, 2010 The link won't work for me. Are you thinking about fitting poly bushes? Quote
jonog Posted November 4, 2010 Author Posted November 4, 2010 The link won't work for me. Are you thinking about fitting poly bushes? Quote
jonog Posted November 4, 2010 Author Posted November 4, 2010 The link won't work for me. Are you thinking about fitting poly bushes?just want to replace them either with oem or polybushes but not found any yet. Quote
james@cjperformance Posted November 4, 2010 Posted November 4, 2010 i believe they need to be pressed out and back in. Quote
jonog Posted November 4, 2010 Author Posted November 4, 2010 Has anyone got any details or photos about replacing these. I understand to replace them is pretty time consuming but what or which bushes if any are available?Sorry about wrong link. Quote
rorenapier Posted November 4, 2010 Posted November 4, 2010 Standard buses cannot be bought, there part of the beam. From what i remember it isnt that expensive to purchase.But you can always buy poly bushes for them, old bushes will need removed (not hard) and the poly ones inserted (yes that easy) Quote
jonog Posted November 5, 2010 Author Posted November 5, 2010 Poly bushes sound good but who makes them the ep82 ones dont fit? Quote
rorenapier Posted November 5, 2010 Posted November 5, 2010 I sure the EP82 ones will fit, i know the ep82 and 91 use different beams but the diameter of the bush remains the same. Quote
CLARKYTRD Posted November 5, 2010 Posted November 5, 2010 I fitted TRD Rear Bushes to my EP91 last weekend, the old ones need to be pressed out and new ones pressed inBoth TRD EP82 and EP91 are the same...RHD Japan do them cheap enough, very handy to fit, just make sure you press them in the same distance as they came out!! Quote
Idrees Posted November 5, 2010 Posted November 5, 2010 I have the TRD ones fitted too and I'd advise buying poly bushes replacements instead as you can simply cut the bush out, as Rory described. The TRD bushes are more of a pain to fit and will involve removing the axle to fit them properly, whereas the others can easily be fitted with the axle attached to the car. Quote
riko666 Posted November 5, 2010 Posted November 5, 2010 The issue is how its fit on both cars -I think it's the EP82 axle where the bush fits into a sleeve and then welded in place, whereas the EP91 has a slightly lip which locates the bush. The bushes vary somewhat, as I've had a nightmare of a problem regarding the installing of bushes in axles; I think I installed an EP82 one into the EP91 one, and it just came loose. Welded the bush in, nada. Quote
