Rhys249 Posted November 10, 2010 Posted November 10, 2010 Hi guys, any one know what the NGK or bosch spark plug codes would be for a GT ? ? ?running standard boost at the moment with a front mount, air filter relocation, decat and up rated fuel pump.And would they be ok to use when i up the boost to 1. bar after christmas Quote
scot-ish Posted November 10, 2010 Posted November 10, 2010 you would want heat range 7's.most of the traders sell them. Quote
Guest cheshireglanza Posted November 10, 2010 Posted November 10, 2010 ^^ what he said any off the traders will sort you out Quote
Jozinobi Posted November 10, 2010 Posted November 10, 2010 NGK Iridium Heat Range 7 are the ones mate for mild modifications.The plugs are fine for 1 bar.Joz Quote
Amjad Posted November 10, 2010 Posted November 10, 2010 I got mine from Ebay, only worked out about £20 for a setThink the code is BKR7EIX or BKR7E-IXReplace the 7 with 6, or 5 depepnding on which heat range you want.. Quote
Rhys249 Posted November 10, 2010 Author Posted November 10, 2010 Cheers guys, I work in halfrauds so i can get them from there on the old traders card thats about al the place is good for lol Quote
