Following up on the last Gauging interest topic regarding service kits, this topic now has prices and i have slightly modified the kit options.
After reconsidering the service kits i am now offering 2 kits oppose to the 3 offered earlier. Instead of a third kit i will be offering a 'Pick and Mix' deal, this way you can purchase the parts you want for your EP rather than having to stick to set kits.
*Service Kit 1*
Genuine replacement oil filter
Genuine replacement 5L of 10W40 engine oil
1L of Genuine Toyota DOT 5.1 Brake and Clutch fluid
Genuine replacement sump plug washer
This Kit comes in at £62.00 Posted to all UKSC Members
*Service Kit 2*
1L of Genuine Toyota DOT5.1 brake and clutch fluid
Genuine Replacement Spark plugs x4 *These are Iridium Tipped spark plugs*
Genuine Replacement Fuel Filter
This Kit comes in at £166 Posted To all UKSC Members
Finally the 'Pick and Mix' offer.
I will make a list of each individual part and price and all you have to do is simply decide which parts you want and contact me to order them.
*All prices are Delivered*
*All Parts are Genuine Toyota Replacement and not a cheap equivalent!*
Oil Filter - £11.50
Spark Plugs - £57 for 4 Plugs
Fuel Filter - £47.50
Auxilliary Belt for Alternator/Water Pump - £12
Auxilliary belt for Air-Con AND Power steering - £13
Auxiliary Belt for NON Air-Con models with power steering - £14
Timing Belt - £35
Timing belt Idler No1 - £92
Timing belt Idler No2 - £75
Thermostat Inc. Gasket - £26.50
Sump Plug Fibre Washer - £1
5L of 10W40 Oil - £28.50
1L DOT 5.1 Brake & Clutch Fluid - £10
250ml DOT 5.1 Brake & clutch Fluid - £6
5L Coolant - £19.50
Bottle Of Petrol fuel Injection cleaner - £11.80
As said previously simply choose the items you would like then contatct me to process your order.
Thanks for looking
Gary
  • 2 weeks later...
  • 4 weeks later...
  • 3 weeks later...
