1990timeismoney Posted November 14, 2010 Share Posted November 14, 2010 Hi ive just installed a aem wideband kit and not shore what the air/fuel ratio should be its running 14/15 air/fuel ratio is this right or have you got to adjust the dial to correct setting for car.any infomation would be great.thanks Quote Link to post Share on other sites
Sparky Posted November 14, 2010 Share Posted November 14, 2010 Thats about right for idle, should be around 14.7 Not sure if you have to calibrate them at all i dont think so though Quote Link to post Share on other sites
1990timeismoney Posted November 14, 2010 Author Share Posted November 14, 2010 Sparky said: Thats about right for idle, should be around 14.7 Not sure if you have to calibrate them at all i dont think so thoughthanks for the reply what should the air/fuel ratio be when driving.thanks Quote Link to post Share on other sites
Sparky Posted November 14, 2010 Share Posted November 14, 2010 all depends on your setup mate, aslong as it stays in the optimum or rich then you'll be fine Quote Link to post Share on other sites
1990timeismoney Posted November 14, 2010 Author Share Posted November 14, 2010 Sparky said: all depends on your setup mate, aslong as it stays in the optimum or rich then you'll be fine ok thanks very much it stays orange when its driving.thanks Quote Link to post Share on other sites
The_Notorious_C_A_T Posted November 14, 2010 Share Posted November 14, 2010 You don't need to calibrate the aem wideband, the inovite one you do. Quote Link to post Share on other sites
