Not going to make a major difference on it's own, but as it says, it's a good start. If you can get the crankshaft pulley as well, you might notice a slight improvement, but don't expect much.
after more research i think dave burwash does both for £95. says on there 7bhp ish. like i have said before im not trying to make my n/a a rocket, as it would be pointless without the turbo, or quad tbs. but i would like to make a nice improvement on standard. and i need to buy something new to feed my addiction!
just want to know about fitting.
i was just about to ask you if there was an improvement on your n/a....... then i remembered its not n/a.
where abouts did you source shorter belt? and did the pulleys need balancing?
thanks.
