joel_ep91 Posted November 26, 2010 Posted November 26, 2010 hey guys need to know what the Combustion Chamber Volume is on a 4efe so i can work out how much i can take off my head. need to know how many cc the is per chamber Quote
micky boy Posted November 26, 2010 Posted November 26, 2010 Not sure if this will helphttp://www.tercelreference.com/tercel_info...ngine_info.html Quote
micky boy Posted November 26, 2010 Posted November 26, 2010 Try it now matey...Not sure if it will give you the answer to your question but its a good link anyway lol. Quote
joel_ep91 Posted November 26, 2010 Author Posted November 26, 2010 thanks mate tis a very good site just doesnt have the info i need thanks anyway Quote
Sparky Posted November 26, 2010 Posted November 26, 2010 If I had a head handy I could measure it pretty easily I was looking for this info also mate Quote
joel_ep91 Posted November 26, 2010 Author Posted November 26, 2010 i can get the FTE volume but not sure if that is the same Quote
mk1kurt Posted November 26, 2010 Posted November 26, 2010 i have a n/a head at home and a turbo head at home they look identical if that helps i can measure tomorrow if you want me to tell me what measurements you need and i will pm them too you kurt Quote
Sparky Posted November 26, 2010 Posted November 26, 2010 Im 90% sure there is no differences dude, the only differences in the head are the valve springs Quote
joel_ep91 Posted November 26, 2010 Author Posted November 26, 2010 if they are which i also was pretty sure they are here is ther info i gathered4E-FTE Specifications:Year: 1989 - 1994Displacement (cc): 1331Horsepower: 135 @ 6400Torque (ft-lbs): 16 @ 4800Bore (mm): 74Stroke (mm): 77.4Compression Ratio: 8.2:1Vavles per Cylinder: 4Valve Angle: 25°Cam Design: DOHCIgnition System: DistributorSpark Plug Gap: .022"Fuel System: Fuel Injected, excess fuel returnHead Gasket Thickness (mm): 1.2Combustion Chamber Volume: 39 ccCars Used In: Starlet GT39 cc per camber it is then ? Quote
mk1kurt Posted November 26, 2010 Posted November 26, 2010 i thought they was 1332 that what it says on my logbook kurt Quote
joel_ep91 Posted November 26, 2010 Author Posted November 26, 2010 4efe is 1332 and 4efte is 1331 its to do with the pistons and all that jazz Quote
