Does anyone have a guide on swapping the starlet reflect panels to glanza?
Or does anyone have a build thread with the swap?
I can only find the one on how to swap the lights.
I have some glanza panels and lights on order and am wondering how to fit them
Thanks, Daniel
bumper and bonnet is a pretty much straight swap, depending on what spec front bumper you've bought tho (96 or 98 spec) you may need to get the bumper brackets from a glanza if its the 96 spec.
everything else is a swap, also you need the glanza bonnet and bumper for the lights to fit because they are slightly different shape to the reflet lights bonnet and bumper
  • 3 weeks later...
I have managed to order a 98 spec front bumper, so hopefully i wont need brackets.
Just had a quick look at the car and think this is all that needs doing.
Bumper ~10bolts/screws? Some look like bitches to get to
Lights - 1 screw and 1 bolt on each headlight?
Bonnet - 4 bolts on hinges, wiper hose?
Is this right?
Is this right?
yes, and there is also like a ball and socket joint on each headlight too
dont forget to disconnect the wiring before trying to yank the lights out too :)
urmmm not too sure dude, thats 1 thing im not good at is wiring
but for taking the lights out you can simply unplug the wiring from the back of the headlights
