yep thy are wat is required for any tunner, plug it into a data logger. with all your other engine sensors and you cant go wrong. do not need a rolling road.
i can install for 80 quid. the inavitive 1 is a bit problematic. you can plug thm into a aftermarket ecu. if you guys get 1 get a digi gauge, as a needle 1 are hard to read acreate wen your on the move. use a data logger guys its the easyest way.
