nazzurro19 Posted December 5, 2010 Posted December 5, 2010 been looking into more power next year as i have more money and i have come across some quite good bargains so i may get them too build myself a forged but what exactly do i need ?i was thinking wossner pistons 75mmlow compression ringsstandard conrods - maybe uprated if money is okacl racing shellsand 265 billet camsi understand other work would have to be done port polish skimming head gaskets arp bolts etcbut is that everything id need ? Quote
Asad Posted December 5, 2010 Posted December 5, 2010 You can use std rods theres nothing wrong with doing so, IF your staying within the rev limit of 7-8k have a look at the Jam glanza iirc it only has uprated pistons and was pushing out 280 odd Quote
joel_ep91 Posted December 5, 2010 Posted December 5, 2010 if your going to forge it put upgraded rods in for peace of mind as the rods will be the weak link in the engine do it right the first time Quote
nazzurro19 Posted December 5, 2010 Author Posted December 5, 2010 oh yeah id stick in the limiter lol so if i was to buy all of the above it would make my engine strongerim so undecided if i want a ct9 hybrid power up kit or a td04 Quote
joel_ep91 Posted December 5, 2010 Posted December 5, 2010 if your only looking to go hybrid or td04 you can run them fine on standard engine alot of people are runng td04 at 1bar Quote
Asad Posted December 6, 2010 Posted December 6, 2010 forged pistons will allow you to take the engine up to higher levels of boost IF within stock revs ~7.5k (although is not just revs which kill rods)....its all about the map if i had the money id just rebuild a high spec standard engine forged pistons and shell out for a decent mapper....if your wanting hybrid or td04 (ive read it runs out off puff by 7k on tgtt) youll be fine with just stock rods get the GT ones if you can. Td04 is more than enough power for a FTE after that your just chasing figures...and traction Quote
nazzurro19 Posted December 6, 2010 Author Posted December 6, 2010 im thinking of leaving engine standard for now and gettingkillamatts ct9 power up kittial ext wastegateemanage blue/ultimateenzo's ct12 hybrid wallbrough fuel pumpi recon i should get about the 220bhp mark with all this plus it will be less laggy and eventually also get a lighter flywheel to help the lag so all the td04 boys around here i should kock their asses Quote
Sanchez Posted December 6, 2010 Posted December 6, 2010 As said mate rods are a must imo, for the sake of a few hundred quid for peace of mind i would deffo uprate them.But if you dont at least use GT rods as they are thicker than glanza rods Quote
durmz Posted December 6, 2010 Posted December 6, 2010 theres no way ide spend all that money on the engine and leave the std rods in there, makes no sense imo.your right saying it can be down to the map, but that also means the mappers only gotta get it wrong once and your fucked, forged rods and youre alot safer Quote
shorty Posted December 6, 2010 Posted December 6, 2010 Im with sanchez tbh, minimum should be, uprated rods and forged pistons. You mention port polish and billet cams, niether of wich are needed realy, and as a heads up the cams give a very lazy engine till around 4.5k rpm so if you want quick response dont get billet cams lol. Quote
