Hi All,
Just a quick question, can the CT9 from a Glanza be used on the GT? its it a direct replacement? or its a lot of hassel.
Any replay would be most greatful.
Thanks ;)
Yes mate, it will fit straight on ;)
The actuator may be a little different, however if you buy a turbo with an actuator fitted you won't have an issue.
Unfortunately it didn't come with one, so its that gonna be a issue? because i was thinking useing the one from the GT.
Guest cheshireglanza
i have used glanza turbo on gt with no probz you will be fine
