Hi guys!
my heater button lights have never worked when lights are on,
i have stripped out all the heater unit..
i have tried taking out the circuit board behind the buttons, bt can't seem to remove the circuit board :confused:
wanted to knw is there a bulb that has fused or??? behind the heater buttons???
Thanks! :)
I could never find the dealer number for mine (ep82 quad) However if you untwist the bulb wire off the plastic base and pull the bulb out... (the wire may snap but it doesn;t matter) you can it to Maplins and get a bulb from there for running off 12v. They cost about £1.25 each. Then place the bulb in the holder again and retwist the wires in the same way. The wires will be thicker than the previous one but still mke the contact it needs to work.
This is what i did with mine.
