sdutton007 Posted January 4, 2007 Share Posted January 4, 2007 Hi,When my ep82 front brakes get warm, they start to rub - the hotter they get the more they rub. They got red hot earlier and the car wouldnt move at all until about 30 mins later when they had cooled enough.Anyone got any ideas why they are doing this and what i need to do to fix it?Thanks Quote Link to post Share on other sites
ecksjay Posted January 4, 2007 Share Posted January 4, 2007 new discs and pads, or the fluids is shot, or, the calipers themselves need a rebuild. Quote Link to post Share on other sites
sdutton007 Posted January 4, 2007 Author Share Posted January 4, 2007 i've ordered new discs and pads because this problem has destroyed the old discs and pads..... they were fine before that. Brake fluid level is fine.How do i rebuild calipers and would I be better off just getting new calipers? Quote Link to post Share on other sites
Idrees Posted January 4, 2007 Share Posted January 4, 2007 Callipers. Same happen to ours. Quote Link to post Share on other sites
sdutton007 Posted January 4, 2007 Author Share Posted January 4, 2007 Callipers. Same happen to ours.Cheers, So all i need to do is put on new calipers and it will stop the problem? Quote Link to post Share on other sites
Idrees Posted January 4, 2007 Share Posted January 4, 2007 Yep. Unless you can get your current ones refurbished or something, but i think it would probably be cheaper to get hold of some second hands one.Search on toyotagttubo.com and your guaranteed to find a pair. Quote Link to post Share on other sites
Ichiban Posted January 4, 2007 Share Posted January 4, 2007 Pads may be sticking in the carriers. take the pads out, and clean the areas where the pads sit in the caliper carriers (clean the carriers also) when rebuilding, use some copper grease on those areas. also clean the sliders Quote Link to post Share on other sites
Nanglebadger Posted January 4, 2007 Share Posted January 4, 2007 I had this problem too, pad was stickin to the disc, caliper was totally shot. got second hand set fitted, solved the problem.Phil. Quote Link to post Share on other sites
