  • Replies 67
  • Created
  • Last Reply
Top Posters In This Topic
Running 1.1 230 bhp
Engine
Apexi Air Filter moved to front bumper
Blitz ss bov
Force Front Mount Intercooler
Jap speed De-Cat
Full blitz Exhuast System cat back
Ct9/CT20 Hybrid Turbo (recoditioned 2 months ago)
External Wastegate
S/S Manifold - custom
Wiseco Racing Low Compression 74.5mm Pistons
Wiseco Racing Piston Rings/Pins
Scat Forged Conrods with ARP Connecting Bolts
Uprated Metal Head Gasket
New Cambelt/Tensioner/Idler Kit
New OEM Toyota Head Bolts
New OEM Toyota Complete Engine Gasket Set
New OEM Toyota Oil Seals
New OEM Toyota Water Pump
New OEM Toyota Oil Pump
New OEM Toyota Valve Stem Seals
Crank Reground With New Bearings
New Mainend Bearings/Shells
Full Bottom End Rebuild
Port & Polished
Block Professionally Rebored/Honed
Head Stripped/Cleaned/Re-Shimmed
Re-Profiled Cams 254/254 with 7.8mm of lift
Air Con Removed
Walbro Fuel Pump
Bee* R Rev Limiter
Dastek Unichip
Running @ 1.1 Bar boost
Suspension:
Tein HA Coilovers
Transmission:
Cusco 1.5 LSD
TRD Quickshift
Exeedy paddle clutch (4 month old)
Brakes
3G Grooved Disk's
Mintex Extreme Pads
standard rear brakes
Alloys
14" Toms
Interior
Boost Gauge
Air fuel Mix Gauge
Glanza Badge on dash
Various parts on the dash sprayed Blue
Black bucket seats with harnesses (original seat belts still fitted aswell)
Exterior
Black window Tints
Glanza badge on bumper replaced with red jap writing saying "Glanza"
Front laguna spliter
I.C.E
Sony Head Unit
Infinity 6'9s
12" sub and amp (cant remember name off hand but can find out if needed)
The car has just been serviced aswell new spark plugs, oil filter, oil change, anti freeze, gear oil. Also has new dizzy cap and rotor arm.
Yeah it is daz
have you been to see it? i didnt like the whole bit about the airbag going off as he hit his head on it because the car infront braked to hard ^_^ for the price he said i could have it for it was a bargain though, id of made my money back by selling the engine and wheels if id broke it.
Replied.. Can any one help me by telling me what a pop plug is as was ment to buy this car two weeks ago but it started leaking water so boy booked it in to garage to get fixed they said water was coming from pop plug
Would this be right??
core plug? they can pop out as a safety feature to prevent the block cracking if theres no antifreeze inside it just plain water when the temp outside drops
thats a good call, and if thats the case it aint a good thing as other things could have been damaged and on the brink of breaking. ice is not an engines friend!
cars like this which raise eyebrows need to be looked at by a couple of lads who know there way round a ep so as not to miss anything.....that way atleast one person will notice something if anything
What will a look out for
for a start make sure the car is cold when you get there so you can start it from cold and check for smoke or noises, when things first start to make noise or smoke they generally stop when the car is warm i.e engine or turbo. defo have a good look for crash damage as i carnt get my head around the airbag going off as his head hit it and a good test drive. but more sets of brains and eyes are better than 1!
Yeah thanks daz will do all that.. A have to take temp insurance for the day just to pic it up
Lol £31 for the day
brakes/alloys/exterior/ice/suspension is a simple visual thing take a print out of the stuff and check it off...any extras and keep hush anything missing point it out
Transmission
- jack it up and spin the wheels cant remember what happens whn youve got a LSD but its been mentioned
- Youve had a EP? youll notice the gear shift and the TRD usually comes with a leather knob
-ask someone what the clutch is like and see if you can notice it compare with your own experience
engine
-the walbro pump is loud apparantly, listen out for it
- check the boost gauge when you drive it does it register 1.1?
- look at the ecu
- the bee*r is a devil thing this would put me off straight away...........
- get the sump cover off (if he wont let you try and sus why if not walk away) youll notice the rods may even see the pistons with a torch
- the head should be quite clean and not shitty looking
- look for new sealant anywhere
-check the colour of the coolant------has it been fixed since the core plug issue?
-when you drive it check for CV joint creeks EPs love eating them from what ive seen
- the turbo should be nice looking take the filter off and check for oil residue
apart from that check panel gaps, boot well, front end.......theres also a tappety knock forged engines make mabe listen out? look for a reciept for the engine stuff?
thats all i can think of lol
Thanks for the great right up mate.. Bee r rev limter getting put on eBay!
The car is defo forged mate a have found out off people got done at toytuning
best way is to ask around, even then be cautious its your money thats on the line not theres so id still check everything i remember a case with some lad i bought some speedline alloys off and apparantly even after his "mates" knew the car he was buying was a shitter they never said anything to him till he realised when doing some work on it
best advice i can give without being there is if in doubt walk away no reason necessary and say youll think about it
Lol £31 for the day
where you get that temp insurance from??
