markv Posted January 9, 2011 Posted January 9, 2011 right lads swapped an engine in my glanza yesterday and the pcv valve broke off when i was swapping it!so now can i run a hose coming from the pcv valve grommet to a breather filter and block the inlet vacumm?as i do not want to pay 40 euro for something i dont need!any help appreciatedthanks mark Quote
Idrees Posted January 9, 2011 Posted January 9, 2011 No, you need the Pcv valve as an normal breather will always be open. Quote
joel_ep91 Posted January 9, 2011 Posted January 9, 2011 what about the race spec rocker covers they dont have a pcv the just plum into a catch tank Quote
markv Posted January 9, 2011 Author Posted January 9, 2011 yeah thats what i was thinking seen alot of race covers just go to a catch can with a breather? i want to drive the car today too to see if the engine is good i tought the pcv valve only opens on boost to leave out excess pressure in the crank and works off the vacumm of the inlet!and if so i block the inlet and run a pipe to a breather then it leaves the engine breath properly? Quote
