N80Jamie Posted January 14, 2011 Posted January 14, 2011 I've just found another car which i might be interested in buying and the seller claims in his add that the ct9 on the glanza is a hybrid. is there any way i can tell if he's speaking truth without reciepts?Thanks, Jamie. Quote
Steve GT Posted January 14, 2011 Posted January 14, 2011 the easiest way to tell while its on the car is have a look at the intake hole size on the turbo, if its a hybrid it will be much bigger Quote
N80Jamie Posted January 14, 2011 Author Posted January 14, 2011 the easiest way to tell while its on the car is have a look at the intake hole size on the turbo, if its a hybrid it will be much biggerNot familiar with turbos yet so where would this be? Quote
Glanza_cl Posted January 14, 2011 Posted January 14, 2011 the easiest way to tell while its on the car is have a look at the intake hole size on the turbo, if its a hybrid it will be much biggernot necessarily, some companies simply bore the housing out to accommodate the larger inlet blade and dont touch the outside housing atallits going to be hard without a receipt, and without knowledge of turbo's checking the turbine blades probably wont help you much as you would have to determine the difference.will just have to gets some receipts or find where the work was done on it and ring the place the verify... if he provides nothing then its probably not.some people fuck there turbo get it rebuilt to OEM specifications and then presume as it got worked over that makes it 'hybrid' lol, some funny people in thw world Quote
Steve GT Posted January 14, 2011 Posted January 14, 2011 lol start with the air filter. find that then follow the pipe the air filters attached too and follow it all the way to the turbo. where the pipe joins the turbo thats where the air intake will be on the turbo Quote
N80Jamie Posted January 14, 2011 Author Posted January 14, 2011 not necessarily, some companies simply bore the housing out to accommodate the larger inlet blade and dont touch the outside housing atallits going to be hard without a receipt, and without knowledge of turbo's checking the turbine blades probably wont help you much as you would have to determine the difference.will just have to gets some receipts or find where the work was done on it and ring the place the verify... if he provides nothing then its probably not.some people fuck there turbo get it rebuilt to OEM specifications and then presume as it got worked over that makes it 'hybrid' lol, some funny people in thw world Seen too many adds now with 'hybrid turbos' no reciepts!! I'll do what you said though and ask where it was done etc. lol start with the air filter. find that then follow the pipe the air filters attached too and follow it all the way to the turbo. where the pipe joins the turbo thats where the air intake will be on the turbo thanks, i'll get the hang of things eventually! Quote
Steve GT Posted January 14, 2011 Posted January 14, 2011 not necessarily, some companies simply bore the housing out to accommodate the larger inlet blade and dont touch the outside housing atallits going to be hard without a receipt, and without knowledge of turbo's checking the turbine blades probably wont help you much as you would have to determine the difference.will just have to gets some receipts or find where the work was done on it and ring the place the verify... if he provides nothing then its probably not.some people fuck there turbo get it rebuilt to OEM specifications and then presume as it got worked over that makes it 'hybrid' lol, some funny people in thw world ahhh i didnt know that. cheers for the info dudeGuess Mr tong just does it properly glad i bought a tongs one then lol Quote
Glanza_cl Posted January 14, 2011 Posted January 14, 2011 yeah i loved the bigger comp intake, but some dont bother... making it very hard without proof to prove that its actually a hybrid, unless your very up on your compressor blades and can tell the difference Quote
