Had a quick look but couldent find any info on this fourm, has any one tried it I've read on a few other fourms about it and seen some builds and the look great! hears a video i found
Its pikey tastic :) them coilover sleeves are used quite abit in honda circles but they justput them on bottom spring seat haha
Look allright to be fair and if someone could get bits cheap could probs do something similar !
allthough starlet shocks arent inserts like that as far as i know so wouldnt be possible (N)
ther not insert if you watch he takes the shock apart and then makes it take an insert like fiting koni inserts I've seen this vid befor and tried to get parts to do it but parts are hard to come by its rele for fine tuning exactly what you want from your ride ie you pick the damper and spring ratings so its exactly to your tast if parts wher cheap it is easy to do but you probz need some nolage to get them as good as say tien who put in a lot of testing on ther coilovers to match up the ratings perfectly
if you get the right parts they are as good as any coilovers but its just that geting the right parts for the right price in the vid they use trd parts dont think they come cheap
