Here is my guide!
BOV type: greddy type S (GEN)
Tools needed:tiny alan key, rag, gloves is your keeping your hands clean (pussys)
Other bits: Rag, meguiars all metal polish, autosol
Time: 35min
Get started.
dirty grime stick to the BOV
you need to undo the 6 alan key bolts that holds the head of the bov to the cylinder
make sure you keep your hand down firm to stop the spring from flying off into the air and you not being able to find it again
also to undo side to side (slack each bolt first)
remove the top
remove the spring
pull out the piston dont tear the lining
start your polish , i am only hanf poilishing it just to clean it up abit am sure there people who could get it brighter this will do for now
pop the pistion back in
spring back on
clean out any grime inside the top hat
clean the screws cuz lets face it you wount stick your dirty dick in a fresh clean bird would ya?
screw back down holding the hat flat and screwing back down side to side
sorted
its up on TGTT so drop us some rep if you read it there to
Such a sexy BOV B)
Nice little guide mate but to answer your question I would put my dirty dick in a nice clean bird, have done many of times ;)
I don't have the nut on the top of mine, is it necessary?
Can I adjust mine using the allen rod on the top or do I need to get hold of another nut to put on top?
