_shaun_ Posted January 24, 2011 Posted January 24, 2011 just went to take my dails out to fit my plasma 1s. went to push steering wheel down but was kinda stiff to give it little bit of force and my music stoped then i spoted cd player/ boost controller/ power meter had stoped working. put it up and nothing happend so went around checking so far ive got this.cd player / boost controller / power meter / window wipers / all lights on dail cluster not working at all . idicators dont work from the stalk but hazard switch works them fineno side lights/rear lights. however my hi/lo beam works fine my turbo timer turns out and lights up but when i turn off ignition the car just instantly turns off. my alarm has an imobaliser that i have to touch a lil pen thing to a little connecter thing on the dash before it will start but this isnt working either however i can just stick the key in the ignition and start it. and finaly my central locking doesnt work either ( its the oem not part of alarm) my guess woulda been a fuse but it seems like alot of stuff for it to be just one fuse?any help would be great its currently pissing it down so unless it stops raining soon wont get a chance to go check anything till tomorow cheers shaun Quote
1987glanza Posted January 24, 2011 Posted January 24, 2011 check your fuses under the bonnet, mine did exactly the same wen i removed mine, not 100% sure but i think its a 15amp (blue one).failing that just check ther are no wires broken or disconnected Quote
(NAS) starlet ep82 Posted January 25, 2011 Posted January 25, 2011 as said above, sounds like a fuse, my corolla did this aswel, turned out to be a fuse from engine bay.. Quote
_shaun_ Posted January 25, 2011 Author Posted January 25, 2011 found the fuse was the big beasty 50a swaped and all working fine now Quote
(NAS) starlet ep82 Posted January 25, 2011 Posted January 25, 2011 found the fuse was the big beasty 50a swaped and all working fine nowglad to hear its alive again lol Quote
Raz Posted January 25, 2011 Posted January 25, 2011 You didn't think to check fuses before posting? Glad its ok though, nothing too serious like damaged/burnt wires Quote
_shaun_ Posted January 25, 2011 Author Posted January 25, 2011 You didn't think to check fuses before posting? Glad its ok though, nothing too serious like damaged/burnt wiresnope was pissing down so easyer for some1 to guide me to what fuse it would be rather than getting soaked looking Quote
