EliteMilk Posted January 27, 2011 Posted January 27, 2011 right i asked on here because i know dont know anyone on the 206 forums and you dont know how nice they are lolanyways there will be a short video to come once i get home my friends 2.0l hdi 206 will not start it turns over but just will not start i have checked fuses, glow plugs, pipes ...everything ...she said right before it stopped the coil light flashed up (pre heat), then engine management light flashed upthere is nothing flashing up on the dash now when u try to start itits like its trying but just wont have it!she ran out of fuel not long back but it has be started since then and been for a run she topped it up with oil & water not to long back too but i checked over all that and its fine :s i haven't a clue i will upload the video lets have some help please guys :/ Quote
Wardy Posted January 27, 2011 Posted January 27, 2011 It might be something to do with the running out of fuel part, Air bubbles in the fuel lines. Was it primed properly when it happened?Also is there a immobiliser on the car to stop it from starting?I used to be a member on 206info.co.uk and i didnt really like it, just seemed like every post was something negative! Quote
Socks Posted January 27, 2011 Posted January 27, 2011 tbh mate.. modern cars. its easier in most cases to get a fault code reader... there avliable on ebay for like £25...AND u can somtimes clear them and the car may start again lol Quote
james@cjperformance Posted January 27, 2011 Posted January 27, 2011 you will most likely need to reset the ecu, its a common problem with them. Quote
