Craig_T Posted January 27, 2011 Posted January 27, 2011 Right,All I need to know is:Do 15" rota grids fit over wilwoods or ksports without spacers?SecondlyDoes anyone know the dimension shizzle so I can work out whether the calipars would hit my current wheels?Cheers Quote
Sparky Posted January 27, 2011 Posted January 27, 2011 Jamesbaa had Rota girds in 15s with Willwoods, im sure he has 10mm spacers so assumed his were high offset Quote
Craig_T Posted January 27, 2011 Author Posted January 27, 2011 Do they come in different offset? I thought grids all had the same? Quote
Sparky Posted January 27, 2011 Posted January 27, 2011 Depends where you buy them, Driftworks has the most dramatic catalogue of sizes and offsets I have seen Quote
Craig_T Posted January 27, 2011 Author Posted January 27, 2011 I see, well in that case as I don't want spacers does anyone know what offsett etc fit? Quote
Keri-WMS Posted January 28, 2011 Posted January 28, 2011 If you find out the confirmed offset of the ones Jamesbaa had, then add the 10mm spacers (by subtracting 10 from the ET## number) you'll get an offset to look for on this wheel that should(?) fit.However if it's more than a few mm different from the standard EP wheel offsets it will affect the handling.Hope that helps, as I mentioned before our 277mm (failing that 275mm) kits should fit without all the agro. Quote
