Starbuck Posted January 31, 2011 Posted January 31, 2011 Just noticed over the last week when reversing that im getting a judder/knocking noise. Which bushes would this point to and are they easy to do?cheers Quote
yaristurbo Posted January 31, 2011 Posted January 31, 2011 could be a sorts mate. the wheels rent tooching the arches or the archs arnt secure? try lookibg into the lower arm bush but it could also be the driveshaft to matey Quote
Arahan Posted January 31, 2011 Posted January 31, 2011 Knackered strut top rubbers can cause this too Quote
daz gt turbz Posted January 31, 2011 Posted January 31, 2011 is it judering all the time on reverse or just on full lock? Quote
Starbuck Posted January 31, 2011 Author Posted January 31, 2011 is it judering all the time on reverse or just on full lock?full lock. It doesn;t do it when in a straight line or slight curved reverse Quote
daz gt turbz Posted January 31, 2011 Posted January 31, 2011 full lock. It doesn;t do it when in a straight line or slight curved reversemine did the same mate. what are your front tyres like tread wise? mine started to do this when my tyres got low but when i had them changed i got the tracking sorted at the same time and it stopped doing it after i got this done, so it could either be your tyres getting low or your tracking is out. Quote
Starbuck Posted January 31, 2011 Author Posted January 31, 2011 mine did the same mate. what are your front tyres like tread wise? mine started to do this when my tyres got low but when i had them changed i got the tracking sorted at the same time and it stopped doing it after i got this done, so it could either be your tyres getting low or your tracking is out.They are slightly low but still legal. The tracking was done when i had the rear wheels done..... they did a check and it was out Quote
daz gt turbz Posted January 31, 2011 Posted January 31, 2011 They are slightly low but still legal. The tracking was done when i had the rear wheels done..... they did a check and it was outhow long ago was it tracked? the amount of pot holes on the roads at the mo means you can easily knock the tracking back out in the drive home from getting it tracked! lol, might be time for some new tyres aswell then, if your front tyres arnt the same make then that could be a reason to as they will grip the road differently. Quote
