Janus Posted February 2, 2011 Posted February 2, 2011 Hello all. Does anyone know which oil is the best to use on a p reg glanza turbo? Also where would be best to purchase it? Also need spark plus, oil filter, fuel filter and coolant.cheers Quote
Amjad Posted February 2, 2011 Posted February 2, 2011 TM Developments are cheap for Fuel filter, Oil filter and coolant. I use Shell Semi-Synth 10w-40 5L oil, £20 from Halfrauds Quote
Janus Posted February 2, 2011 Author Posted February 2, 2011 TM Developments are cheap for Fuel filter, Oil filter and coolant. I use Shell Semi-Synth 10w-40 5L oil, £20 from Halfrauds Thanks very much. Is this the stuff you mean?http://www.halfords.com/webapp/wcs/stores/...tegoryId_165581 Quote
Janus Posted February 2, 2011 Author Posted February 2, 2011 Or this maybe?http://www.eurocarparts.com/ecp/p/car-acce...p;0&CC5_277How often should I change the oil too? Quote
Amjad Posted February 2, 2011 Posted February 2, 2011 That's the one! They're both basically the same I guess!Most people change their old in Glanzas/GTs every 3-5000 miles. Probably the latter if you don't drive it very hard but obviously you can keep an eye on it and decide when yourself Quote
Janus Posted February 2, 2011 Author Posted February 2, 2011 That's the one! They're both basically the same I guess!Most people change their old in Glanzas/GTs every 3-5000 miles. Probably the latter if you don't drive it very hard but obviously you can keep an eye on it and decide when yourselfThanks, that's helpful ;) Quote
