ep91_glanza Posted February 7, 2011 Posted February 7, 2011 Hi has anyone took the casing off a gearbox before ??ive took the 10 or 11 bolts holding it on the outside off and the 3 on the inside off but still seems to be holding on.....all the liquid gasket is off and its apart but wont come further than 10 mm off the gearbox. Cheers karl Quote
GAZ@A&G_TUNING Posted February 7, 2011 Posted February 7, 2011 you changing the diff dude?, look in there and you can see the selector arm for the reverse, there 2 12mm inside going into the casing side Quote
Ryan-11 Posted February 7, 2011 Posted February 7, 2011 you changing the diff dude?, look in there and you can see the selector arm for the reverse, there 2 12mm inside going into the casing sidex2 there a bit of a bastard to get off with out dropping them too, also make sure u take the allen key bolt out the side of the box, it has a ball and spring inside, take them out. Quote
ep91_glanza Posted February 8, 2011 Author Posted February 8, 2011 Ok cool they look canny akward like. Ive got to swap the casing over because my clutch went and the bit where the bearing slides up and down has broke into pieces(nightmare) how come one of the most important bit of the car is made out of very soft metal aarrghh cheers mate Quote
ep91_glanza Posted February 9, 2011 Author Posted February 9, 2011 Does anyone know if the gearbox housing out of a normal starlet is the same as a glanza one??? Quote
