Hey guys what exactly do you get with the complete engine gasket set?
Seems quite expensive for a few gaskets or does it come with stuff like crank seals, oil pump seals etc?
Also can you buy one WITHOUT headgasket???
Cheers Lewis
It comes with everything you need.
Head gasket, manifolds, turbo, stem seals, cam cover seal, spark plug seals, oil pump seal and loads of other bits.
It's well worth it as the stem seals are around £5 each from Toyota and you get all 16 seals with the kit. And you can also sell the parts you don't need such as the HG and CT9 gaskets so you get around £30 returned from those bits.
I thought the same before I ordered it, if you had to buy all the bits individually it would cost a fortune!
Don't forget the thrust washers.
