The tacho runs off the negative side of the coil. There should be a wire on the plug for the dash on the engine loom that has a black wire with orange dashes - from memory thats the wire to use for the tacho
anything i've researched about this says to link into either the (ig) at the diagnostic box or black and white wire at the coil.....is this right???? or should i go to the loom beind dash?
