Hi all the glanza has its first mot this month. Ineed to get it through the mot without a cat so anyone know of a place i can go that could help me with this pm me if necassary. the rear fog is shot and i dont have a horn rigged up either.
i also would like to change my gear oil what is the best/recommended oil to use?
can anyone help me out with changing my gear oil as well as the sugar cube that connects to gear linkage im in maidstone and am willing to travel. i think i have forgotten some stuff? i will add later
your gearoil, the plugs on the front i think its a size 17 from memory
and your needing 75w90 transmission fluid
enzo what is a decent brand to use ? also have u ever had or know anyone with a gt or glanza with a stiff gearbox after clutch fitment. my gear box is so stiff selecting 1 +2 and i have even took to a transmission specialist and he dint have a clue? i have read around on both forums and this seems common with no one knowing a decent answer? i will try the sugar cube thing and see if it helps at all
