Russleh Posted February 18, 2011 Posted February 18, 2011 at the final hurdle with gettin my n/a up n running again. starts first time everytime but then cuts out . ill add a video. in the vid i start it 4 times 1st time just a normal start 2nd time i try to start without turning the ignition all the way off 3rd time just to show that when i do turn it off then it will start first time again 4th time i put my foot on the accelerator a little. hopefully with the help of a rubbish video someone should be able to give me something to work with cheersRussell Quote
k1r4n Posted February 18, 2011 Posted February 18, 2011 hey mate this mite not be the case for you but this same problem was happening to my old n/a conversion turned out it was the thermostat /engine temp sensor ( its near the dizzy and has a green plug) - give that a look over with a multi meter or do a self diagnostic Quote
Russleh Posted February 18, 2011 Author Posted February 18, 2011 i have a spare head and all the sensors i think so will give that a bash tomorrow thanks for the idea mate. any others ? Quote
joel_ep91 Posted February 18, 2011 Posted February 18, 2011 faultyy tps? all your vaccum line on Quote
Russleh Posted February 18, 2011 Author Posted February 18, 2011 dont think it will be the throttle position sensor because it worked before and if it was that would it not stay running if i gave it some gas. as far as i can see all vac lines are on. Quote
