right building the engine this weekend so would like to know the way the shell bearings go in, there is a small cut out in the bearings, a oil way.do thesde go together or oppastite(yes i cant spell)
thanks danny
pic from anyone would be great
as above they can only go on one way and the caps are numbered and no.3 had an arrow on it that should point towards timing side. then just put the others on so that all the numbers read the same way round.
ah for the rods. well id just take a look at what i said about the other ones ( main bearings ) and see if the cutouts are the same side as each other or not.
hes on about big end bearings though. so yeh they can only fit on the conrod one way and only fit in the cap one way but when he puts the caps on should both dimples be at the same side. thats what i think the question is lol i made that mistake aswell of not noticing which way there were when i took it apart in the first place
