Shahzad Posted March 1, 2011 Posted March 1, 2011 Hi,I have got a hold of a corolla inlet mani. Before i attempt to fit it is there anything i should watch out for?Will i have to replace the intake and Tb gaskets?The How to guide does not load up here. Quote
Amjad Posted March 1, 2011 Posted March 1, 2011 If you're careful you may be able to reuse the gaskets, but the TB ones are known to cause idleing issues wen they split to may be worth replacing themYou'll also need a longer vacuum hose for the MAP sensor on the firewall Quote
