Hi lads, My car failed its MOT on emissions, where can i get a new cat from, or can i get one off another car from the breakers that will fit ?
Iirc the cat tests aren't the same as uk cars so your car shouldn't of failed on emissions even if you had a de-cat. Were the emissions tested when the car was idle?
Ah i didn't know that, i just assumed was the same throughout most countrys I think it was tested at a fast idle ? I'll have look on the sheet I got when I get home
As with above, should pass without a cat, mine passes everytime no questions asked with a decat fitted...one time it failed for having no side repeaters though! Had to get a mate who once trained MOT testers to go in and have a word...good times!
Right just had a look and it says on the mot fail certificate that it was at a fast idle ? I assume this
Means they had it reving to some extent ? Cheers for the help by the way lads :)
